Low microphone volume
Meneerf
when i'm having calls or send voice messages over whatsapp, it appears my microphone volume is very low, even when talking directly into the mic.
i don't use any covers so the mic is free. i also don't use app's that would make the mic operate badly...
on the phone i can't discover mic options..
i hope sony can give me some answers on this.. it's a brand new phone and i'm a little dissapointed by this..
10 REPLIES 10
CameronT
Champion
Hi @monsieurf, welcome to the community. I am sorry to hear about this issue. Slightly_frowning_Face
Do you only have the problem in WhatsApp or does it do the same thing in other apps?
Can you please test the microphone under Settings > About phone > Diagnostics > Test > Microphone.
Can you also do the same thing in safe mode too?
Meneerf
well, it seems the overall volume of the microphone is quite low.
when sending a voice message with whatsapp or facebook messenger my voice is quite weak
Ян23
Translation via Google translate:
At me too same. Imenno in WhatsApp
У меня тоже самое.Именно в вацапе
profile.country.US.title
Qatrium
@Ян23
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
CameronT
Champion
Is it the same in the diagnostics test? If so, you may wish to contact your Local support team.
If not, and it is only a problem in third party applications you may wish to contact the application developers to notify them of the issue.
ZmajBosne
Official Sony Xperia Support Staff--
Your advice about settings is missleading  : (    There is not Diagnostic and test mic on Sony XA2
something As I connected phone with jack pins on AUX in car radio Nobody can hear me, yet with the old Sony Z1 compact never had any problem.
Hope that you will do something soon enough
Thanks in advance
B_XA1
In phone app type:
*#*#7378423#*#*
and it will open Service/Diagnostics. Tap on Service Menu, than Microphone, record your voice than listen. Same for the Secondary Mic.
ZmajBosne
Thanks, that is something to begin with ive got in to settings .
But unfortunately i can't change anything, like to increase volume on microphone sensitivity...All you can do there is test what already is preset  and that's it  : (
HenrySimoes
I have a big problem on my Sony XA1... normal calls ZERO mic sound, if I put on loudspeaker it´s working fine!
I test with *#*#7378423#*#* my XA1, and the main microphone don´t work at all.
And the secondary it´s working fine.
Is it hardware or is there something I can do by software???
Regards,
Henry
