MMS group
Elo49
MMS group
MMS grouped
Hello, I just bought my xperia xa2 and I can not send MMS grouped, a message asking me to change the settings appears but I can not find the parameter in question?
Thanking you
MMS groupé
Bonjour, je viens d acheter mon xperia xa2 et je n arrive pas à envoyer de MMS groupé, un message me demandant de changer les parametre apparait mais je ne trouve pas le parametre en question ?
En vous remerciant
4 REPLIES 4
Uliwooly
@Elo49
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm assuming that you are using the preloaded messaging app, do you have data enabled? (Not WiFi)
sc777
I have the same problem ( and I am also a french user 😞
 - I can not send grouped mms Angry_Face
 - I have looked on the Web but the option to enable grouped mms does not appear in the parameters menu.
I guess this is  a problem with the Android version.
Any help very much appreciated Slightly_smiling_Face
profile.country.SE.title
BrunoS
I havet same problem as the French user bit n Swedish. Pls, advise how to send GROUP-MMS. Bruno
sc777
Well,
 The customer care replied to me that software updates should fix this solution some time ago ....
 Given the date of the first issue, the update will never come ...
 I am very disappointed by Sony: when you buy a phone, you at least expect to be me able to share MMS to a group, which works for the basic Android layer ....
For this reason, I strongly advise you to avoid , ie not buy,  Sony phones
