After the last update (1.97), if you set an mp3 as ringtone for calls or alarm, in the settings menu of the phone it is displayed correctly, but if you go to Call (on the screen) - 3 dots top - settings - Sounds and vibration, it displays 0, no matter if the mp3 is on internal storage or on sd card.
Other things discovered:volume for incoming calls, notifications and alarm has increased, but it has decreased for media, no matter if through internal speaker or headphones (jacked or bt); signal (wifi and data & voice) strength and stability are things of the past: loses wifi connection where there used to be 2 lines (I know my house :)), drops calls and switches data connection types in areas (like subway or elevator) where I had no problems, resulting in faster battery drain than on my previous version (4.70 Android 6).
I hope an update will come soon: 0 is not much of a problem but signal is.
