No internet via LTE
My Sony Xperia has no internet connection via LTE connection. Wi-fi works normally. Recharging the operator settings and starting does not give anything. Regards
Brak internetu przez lte
Mój Sony Xperia nie ma internetu przez połączenie LTE. Przez wi-fi działa normalnie. Ponowne ładowanie ustawień operatora oraz uruchamianie nic nie daje. Pozdrawiam
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Does 3G data works? how old is the SIM card? has your carrier network enabled LTE data on your account?
I have trouble touching
Dokunmatiginde sıkınti var
All of the sides of xa1 are touched by the sides
Butun xa1 lerin yan ekra taraflarinin dokunmatigi bozuk
Elaborate on the issue as much as possible.
