Problem with microphone during OK Google setup
Medik_201
При настройке "OK, Google", появляется уведомление "проблема с микрофоном", хотя при диагностике все работает. Как решить проблему?
When setting up "OK, Google", the notification "problem with microphone" appears, although everything works in diagnostics. How to solve a problem?
Translated with Google Translate.
Uliwooly
@Medik_201
Could you post a screenshot of the error/issue?
