I am using Xperia xa ultra dual.. Recently got update to nougat... After updating, my SD card became inaccessible.. Neither I am able to move contents to memory card nor I can view contents using file commander or any other file manage apps...
Well I am also having touch screen issue, while using mobile connected with laptop using data cable..
Please help me with you valuable suggestions.
Thanks, Dinesh.V.M
I have the same issue too. If you found a solution please do post it.
@DineshVM wrote:Hi,
Thanks, Dinesh.V.M
Did you tried simple format it? Most time it's helping, but the first do copy of files which is in SD card, coz format will erase your SD card
