Sound and remove icon headset
Luckylove22
How can u take of the headset icon it bothers me plus I can't hear anything I reset it and still nothing
Uliwooly
@Luckylove22
If you see the icon on the notification bar and there aren't any headphones connected then there's something inside that is causing that issue, use a flashlight and check if there's anything inside.
