After the latest security update (. 400) the fingerprint sensor had gone from super quick to anything from 1-20 seconds or not at all to activate. Have reset the finger prints and entered new ones but there is still a clear delay from the sensor after the update.
I have no such problem. Updated to the latest version and figerprint sensor works just like before.
Same issue here with my XA2. Before the 400 update, I am happy with how my fingerprint sensor works. After updating to 400 it took me a while to unlock my phone. Most of the time, the sensor don't work at all, I have to restart my phone just to make it work again. I dont restart my phone when I am on the old software, never encounter this problem before. It's very frustrating when I am on hurry.
Just saw same issue in XA2 plus topic here /t5/Xperia-XA2-Plus/Last-udate-50-2-A-0-400/td-p/1386217#gref
Hope Sony fix this ASAP
Fingerprintmanager does´nt work without any "install app" ...
I deleted the 2 prints and treyed to insert 2 new one; but it does not work
If I touch the sensor nothing happend
Thanks & kind regards
Leo2703
Fingerprint sensor completely unresponsive after recent system update
So after update 400 the fingerprint sensor stayed broken which annoyed me too much to deal with so I have rolled back the OS to build 379 and everything is great again!
Hi Drpies
Seems like sony is unresponsive too about our concern :). How did you roll back to 379? TIA
Sony said I couldn't do it but I did some internet searches and found a programme called newflasher, which is discussed at length on XDA forums.
