When I plug my Xa1 Ultra into my computer, it begins carging but the option to transfer files (menu) does not appear. Is there a place where I may have turned off this setting and if so, how do I reset it?
My wife has the same phone and using the same cable it connects just fine and the menu does come up.
Done and Done.
In each case, my wife's phone works fine and mine does not.
