Cuando quiero cargar el movil,al meter el cable USB siempre tengo que ir a ajustes y ponerlo en modo carga pero nunca se queda en ese modo y tarda un rato en empezar a cargar.Tengo el cargador sony original y carga petfectamente, es solo que no me carga el movil si no pongo a mano en modo carga y no en transferencia de datos,que es el modo que se activa por defecto. Porfavor respondedme cuanto antes.
When I want to charge the phone, when I plug in the USB cable I always have to go to settings and put it in charge mode but it never stays in that mode and it takes a while to start charging. I have the original sony charger and charge it properly, it's just that I do not charge the phone if I do not put it on hand in charge mode and not in data transfer, which is the mode that is activated by default. Please answer me as soon as possible.
gt
