Very slow load
Xiimmm23
Very slow load
Very slow load
My device started charging very slowly, a week ago they changed the charging connector because it was not holding the charger
And now I'm slow to load it with its original charger
Does anyone have an idea why or what should I do?
Carga muy lenta
Mi dispositivo empezó a cargar de manera muy lenta, hace una semana le cambiaron el conector de carga debido a que no agarraba el cargador
Y ahora carga lento aún cargandolo con su cargador original
Alguien tiene idea del por que o que debo hacer?
Uliwooly
@Xiimmm23
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
You will have to contact your Local support to get it inspected, but make sure to test different usb cables/wall chargers.
