Hello,
I'm from the Philippines and just updated my phone almost 2 weeks ago. The IR Blaster is working before when I bought the phone 2 months ago. And when I updated my phone to .253 firmware the IR Blaster suddenly stopped working.
Am I the only one experiencing this issue? Hope this is a software issue.
I need a solution to fix this. Any advice is welcome!
Could you be more precise. I use zl. Ir blaster works great though there is a bug in learning signal.
Well, I have my settings for my TV saved. It was working. But when I updated to .253 and used the remote control its not working. I even tried using different device types.
K just check whether the ir blaster lights up when you click on any function. It's near the power button. If it works try a repair using sus or pcc.
