Abnormal Diagnostic test light sensor failure
xznewbie
I did conduct diagnostic test on my xz and noticed that the light sensor is not working as directed in the test resulting in failed test warnings. .
I checked the RAM performance but there is red triangle with an exclamation mark showing 2.11 go used out of 2.71.. What does it mean...? How can I rectify it to remove those alarm marks..?
12 REPLIES 12
profile.country.PH.title
MarlonUk1
Can you please upload some screen shots of the diagnostic results and the ram error.
Uliwooly
@xznewbie
Which test are you referring to?
xznewbie
You should check setting>about phone>test>light sensor then follow the prompt for diagnostic test. Everything was fine according to the test except for the light sensor . which displays the test failures. .
then for the RAM.. settibgs>about phone>facts^RAM.. check if your RAM does not show any red triangle marks with an exclamation mark inside.
xznewbie
BTW.. How do you upload the screens hot in this forum through your Xperia xz phone.?
Uliwooly
@xznewbie
So you are referring to
Settings > about phone > DIAGNOSTICS > test > select the test.
xznewbie
Yes... I run test on all apps and it's only the light sensor that exhibit a failure. It says when you cover the upper part under a bright light the screen should dim.. But it did not so answered no and the score was a failure.
xznewbie
Hello  guys,,  here is the screenshot of the light sensor failure in my  diagnostic test in my xperia xz..  How can this be rectifiedScreenshot_20161212-044913.png
CameronT
Champion
Hi @trashcan,
I am sorry to hear about this. Do you have a case or screen protector on your phone?
xznewbie
I have a screen protector on it. Why...?
