ADB driver XPERIA E
Samank
ADB driver XPERIA E
Hi all,
where do I can download ADB driver for XPERIA E?
when I connect my Xperia to PC, at device manager I see my XPERIA only as other devices and ADB driver is not installed.Windows update cannot find
any driver for Xperia E.Sony doesn't have any driver for this phone.
10 REPLIES 10
Samuel1
Hero
All needed drivers are included in the PC Companion package. Have you installed it?
http://www.sonymobile.com/update
Samanka
I have installed Pc companion, but my Device Manager show at this time, Other devices-Android ADB interface is without driver.I tried it at Win7 and Win8, but result is the same.My Xperia i see as portable device.
Drivers from PC Companion doesn`t work.
Samanka
I answer myself,
it is needed when conect Xperia to PC open Device Manager -> Other devices ->Android ADB interface -> update driver -> search in PC - wait until all manufacturers are loaded ->choose Sony or Sony Ericsson -> find ADB interface driver -> read -> voila it's work
gopal_amlekar
I am having exactly the same issue with Xperia E on Windows 7 (32 bit).
Following your last post, Sony / Sony Erricson shows different ADB interface drivers such as Sony sa0101 ADB Interface driver, sa0102 ADB Interface driver.
Which one is correct?
Mellowship
This is easier than it looks. I had the same problem, and I just had to configure my phone to use the right usb connection (mass storage).
Just go to Definitions -> Xperia - >Connectivity - > USB and choose MSC instead of MTP! The PC software should be able to detect the phone immediately.
Note: I'm using the good ol' Windows XP! Best microsoft OS ever!
junaid2001
In Win7 32 bit,
I have updated PC Companion Installed. Just used
Device Manager -> Other devices ->Android ADB interface -> update driver ->Browse My computer For Drivers->Let Me Pick from the list of Device Drivers on My Computer->Android ADB Interface-> Next -> {Update Warning } -> Yes.
So, far, its working fine.
junaid2001
It works on my Win7, but not XP ..
any clue?
suuny
There is no "Android ADB Interface" driver on my list of Device Drivers. How do i get it ? Please help. I am trying to connect my Xperia E to eclipse on Win 7-64 bit. Thanks ..:smileyplain:
junaid2001
don't know any exact method..
after updating PC Companion,
Adding ADB 4.1 simulator in SDK  ,
Enable USB Debug in Android
it was showing "Android ADB Interface" (with missing drivers) in list.
and this isn't working in WinXP-32bit, So i havn't quite figure out what's missing. so far.. its basically a hit n try method for me.
