Dear Support Forum,
Few days back I have updated my xperia p 4.04 to 4.1.2. After Updating this frimware my device get lag in call log and also while scrolling the call log it gets struggle to scroll smoothly. I have made a issue report in google code page, I have received the following message.
| 1:35 PM (3 hours ago) | |||
Regards,
Shan-Rockz
@ all people !!
I jus Bricked my xperia p and jus reverted to sony stock rom and still i don face any lag in stock rom ..
All who have lag pls root ur device and install semcphone apk from xda site !!
Could upload this apk or share a link, please.
http://www75.zippyshare.com/v/40742403/file.html this is JB MoonBreaker v3.5 Rom's semcphone.apk .. try this !!
I have removed "Android Device Manager" from "Device Administrators" list under Settings/Security and problem resolved. You can try and remove any extra software from Device administrators list. Only exchange email is selected now.
Thank you jackxperiaP just instaled and it works for now. Lets see what happend after couple days? Do you have phonebook and mesages aps? (Black versions)
http://www23.zippyshare.com/v/41528415/file.html conversations
http://d-h.st/N6y phonebook
this s also from the same rom .. take back up and try !!
jus browse xda site you will get a lot of apps !!
Rooted right ???
Thank you. Yes I'm rooted. These aps are ported from Xperia Z? I'm happy with stock rom except phone lag which is very annoying. Sometimes I can't even answer the call!!!
Other problem is GPS which isn't working at all or the accuracy is worse than the cheapest phone. So I'm using external bluetooth Pentagam GPS which is great for navigation. I'm waiting for update from Sony... because - YES I'm using Viber, and I like them.
You were right. Call lag is back after factory reset. It was nice having a proper phone for a week and now back to laaaaag.
is the same problem of Xperia GO!!!!!
Sony we are waiting!!!!
Same problem
How can we tell SONY about this?
