The clock widget on my phone shows that I've set an alarm for 4:56 even though I haven't. The alarm doesn't go off at the time but it just shows the alarm on the screen as being set to some particular time.
At night it shows 4:56 AM. Once that time has passed it shows some other time. Thereafter it shows some other time. I find it very annoying because when I actually set an alarm it doesn't show up on my main display screen.
Hi Jake. Thank you. I realised the problem. An application I had installed was the cause of the issue. However this happened only after I completed the latest software update which is strange. I deleted and reinstalled the application.
Thank you.
Btw do you'll face picture quality issues with Z2. The pictures from my phone are so bad that when I compare it to phones that are cheaper I'm jus irritated with my phone.
P.S. I have been an ardent Sony lover and all my phones have been Sony but I'm really disappointed after using this piece.
