ambient light senseor problem after changing display
austin27
have changed the Xperia vs display and afterwards having problems in ambient light sensors.
they don't work during making calls and also doesn't auto brightness adjustment.
can anyone help me???
Samuel1
Hero
Did you change the display yourself or did an authorized service center repair it for you? If a service center did it, I suggest that you raise this with your local support team to check status and how to proceed with this in the best possible way.
Local support.
austin27
yes I did it myself but wen I checked in service testing it was okay like values change as light comes.
I think there may blockage in New display so have to remove everything and.check once.
as this phones is not available in India so they don't offer any support.
