Android Market Application
does anyone has a solution ( not Rooting Solution) to download the android market for middle east countries " Saudi Arabia" ?
I just knew that users can now access the market through PC and download free and paid applications.
but to do so you have to sign in 1st to market from an android device.
awaiting you ppl for your help and answers
The market should be pre-installed...it always is
However, since you've asked.....
http://www.megaupload.com/?d=MBGKPS0U
Drop on your SD card
from your phone, use any file browser to find the apk file
click it and select install.
If you don't have non market apps enabled, please follow the instructions that pop up to enable them.  After you're done with that, click back
You should be at the folder containing the apk again.  click it and select install once more
It shoudl update and you'll be all set!
Uliwooly
once you install the market you can check this out
https://market.android.com/
it's another way to download apps from the market through your computer
