Battery charge level indicator problem?
Witalij_Schraje
I have my Sony Xperia V cell phone since Saturday and have expired two times same problem: the phone was shut down because of low charge level even if the battery was charged. The phone does not weak with power button until I have removed the battery. After that I have turned the phone off and turned on. The buttery was charged above 99%. I thin, that the is a bug in the battery charge level API. I suppose that error occured after I have changed SD-card.
Kernel version is 3.4.0-1731-g55b052b2-00759-gd9ee069, Build number is 9.1.A.0.490.
Thank you
4 REPLIES 4
Johan
Master
Have you tried reinstalling the phone software using SUS?
http://www.sonymobile.com/gb/tools/update-service/
Let me know if this remains after reinstall.
Witalij_Schraje
In the last month I have not expired the problem with the battery. I have not updates software and have not changed the battery. Therefore I do not see any necessity to update software.
Is there is any possibility to install updates under Linux?
By the way, it is really long time to react for a support.
GoJohnnyGo
WS: It is possible that your battery is defective. I would take the phone in for warranty repairs.
Witalij_Schraje
GJG, so far, the problem does not occur I will not do nothing. If the problem will occur ones more I will take my phone in the warranty.
