Battery need to be charge everyday two days.
I'm using vivaz pro for a month. My problem is the battery need to be charge every two days. Only used for a few calls and messages. The seller said it's because the screen consume more power. It's true? Please help me.
12 REPLIES 12
Cheers!
Same here, fellas, and I do not use my phone so much to empty my battery so fast. I didn´t use to get picture, watch movies or even music just phone calls and messages.
I do not turn off when night comes and I sleep but battery goes dry after 2 days...
Customer service said same thing to me: "it's because the screen consume more power" but I think it´s very weird.
You need to optimize display, luminous intensity, and other settings on the middle to get the best result that the battery can provide, and it is 3 days max.
you guys are lucky. mine lasts less than 12 hrs...
If you are using Roadsync, try setting your sync schedule to every 15 minutes (do you really need push?), and set your peak times to when you are awake (you don't need it when you are asleep.) Are you running Twitter and/or Facebook in the background? Have Bluetooth always on? Some suggest that you don't need 3G unless you are using the Internet as 3G uses more power. Play around with these and you might extend your battery time.
Thanks preguntas. Sadly, I have done all you suggested and it does not help. I have roadsync on every 1hr, then after hours every 4 hrs. No BT, facebook, twitter. I have the email app syncing every 30min... Then calls, text, and a bit of web.. As I said, you guys are lucky
As I said upper, i do not use my phone apliccations, just basic.
But still my battery goes out very quickly.
Thank you for all reply here. Maybe cn be usefull for others customers.
As I said upper, I do not use my phone aplications, just basic.
I think the gadget works this way, running out energy even whether we don't use all aplications...
Thank you all for reply and support here.
Maybe all these answers can be usefull for others customers to get improve their mobile.
cheers!!
By default your phone works in dual mode - uses GSM+3G.
If you are not using 3G , you go to settings and select GSM mode only, this will give you one or more days of battery.
Cheers!
Sorry for abusing you, but I am somekind of nobie with these stuffs Thinking_Face
Can you show me the path to do this, if dont you mind, sir?
