Battery problem
Battery problem
Since i made update to 2.1 my battery have been charging fully very slowly, and now after 5 days after i made an update my battery charges only to 47% or goes over 47% and than drops to 47. what to do, buy a new one or RMA it ? if RMA where can i do beacuse i can find any way to do so.
7 REPLIES 7
Just check these settings in your phone
Tpa Settings and check under
Wireless Networks make sure both WiFi and Bluetooth are not ticked
Accounts and Sync that Background Data and Auto Sync are not ticked
About phone>Software update that Auto Search is not ticked
Then turn off the phone leave it a minute, restart it and put it on charge for a couple of hours
After turning off the phone, remove the battery for at least 30 seconds. I found this little extra step works.
Now it does not charge at all it just shows 1% all the time
suze
Leader
Basically you have a number of variables with battery/charge problems.
1) Is it the plug unit -  to eliminate this see if the phone will charge whilst attached to a pc.
2) Is it the USB cable - do you know anyone else with a Xperia phone to test with their cable.  If not go into a mobile retailer and ask if they have a demo model that you can test the charging ability.
3) Is it the USB socket in the phone - if this is the case neither the plug or PC will be able to charge the phone and the pc shouldn't be able to see the phone.
4) Is it a battery issue. - same as number 2, ask a friend if someone has same phone or go into mobile retailer and ask if you can test your phone with their demo model battery.
It could be any one of the above so you need to start narrowing down the possibiliites.
My theory (and 3 cents worth) is that it might be the duo ICs in the battery. Remove the battery for 30-seconds yet?
Well i went today to local SONY STYLE store and i just switched battery from the model displayed, and it works fine now !! problem solved
Good for you. Congrats.
