Black Screen Problem
Elixir00
Hi Everyone,
I have a problem here with my phone and its almost a month. I've kept doing research and a lot of reading about my problem but it seems no one has the solution.
The problem is my phone Xperia L has Black Screen problem. I know my device is still working but it doesn't have display, I've already have tried the SUS and PC companion many times but doesn't help and I already brought it to a service center and they've said that there's a problem within it's board and I decided not to do replacement or repair since the warranty is already over. I just keep wondering that maybe someone can give me an advice because I've been wondering if I go for a replacement or maybe I someone here already solved the problem without changing any hardware or board. I hope I can here from you guys.
My device status.
Battery is still working,charging
Sim card and SD card still working, I can call my phone and I can also play music by hitting play button on the earphones.
Software and firmware fixed no problem with software
Touch sensitivity still working because I can still shutdown the phone whenever I want to without removing battery because I still remember the screen options if I hold the powerbutton,(Shutdown,Screen Capture,etc.)
The real problem is no display at all. Hope someone can help me or maybe someone can suggest to recycle it because I can't afford to buy board replacement,it cost a lot.
carlo12x888
But you need to repair it because the problem is maybe the software 😞
Elixir00
I also thought that it might be the software because my phone isn't damage at all or even experience overheat, it's just one day while it's charging,when I checked, it appears just black. I'll just wait for any software update from sony I hope they find any solution about this.
carlo12x888
I hope they fix this issue
