Hi
I reluctantly replaced my Samsung Galaxy S2 with an Xperia T, as there was saltwater damage with the S2 & the NatWest Advantage Gold's insurance company would not replace it with an S3. I am sure that it is not as bad as it appear,s from my first impressions, for example, I have discovered that the camera seems pretty good.
A couple of questions about this phone:
Bob
1. remove them by manually deleting the /system/apps/ for a rooted device
2. idk
3, xperia t is not waterproof
4. idk
5. xperia t has tethering and also xperia link (TM) whic is exacly for your needs.
2. No, unfortunately not.
4. Not sure, but in some cases it's possible to extract backups to get the contact/calendar files out. You should be able to import these files to gmail and get the contacts out. Not sure how this works with samsung backups.
Samuel
Thanks for your help: perhaps Sony will address the contact widget problem, although I expect they will not!
I presume you have an Xperia T. It still seems to me that it should be competing with the Samsung Galaxy Ace 2 & priced accordingly. It does not seem to be a high level phone to me, but I do not use my phone for music & perhaps it appeals to music aficionados? Do you like the phone? Perhaps it will grow on me! I will be out of my Vodafone contract in a few months & can upgrade to something more suitable for me, if I do not start appreciating the phone.
Bob
