I'm having trouble listening to music through sbh52. When playing music through any application affected by noise. Does anyone have similar problems? How to solve this problem?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Have you been able to verify this with other headsets or Bluetooth audio devices as well?
You could try to master reset the SBH52 and check if you notice any difference.
BTW, do you listen to music in your SBH52 using headphones or the built-in speaker?
i have same problem. a noise appears after updated 14.2.A.0.290 Android 4.3.
i tried to master reset the SBH 50 ,restore my device firmware , its not work.
fyi : on 4.2 sound on SBH 50 was perfect.
the problem wasn't appear on wire-headphone.
And a Smart connect app last-update not compatible with stereo bluetooth headset SBH50 App (But when removed update, its become work properly)
I have same problems with sound after updated 14.2.A.0.290 Android 4.3. But i'm using headset pro MW1 with the last update. About Smart Connect app - same problem.
On previous android 4.2.2 everything was fine.
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
I also have the same issue with SBH20 since update...
I have the same problem with Xperia Z after 4.3 update (10.4.B.0.569), with BT music streaming to Sennheiser M550-x and Jawbone Big Jambox. No noise via wired connection.
UPD: found this app: https://play.google.com/store/apps/details?id=de.devmil.xperiabluetoothmediafix , seems workingm but Sony must make a fix on their own, I suppose.
