Camera problem
Nanley
Camera problem
Hello everyone. I have a confusing problem with camera. When i open camera app i see black screen. After a while freezed screen appears with horizontal colored lines and camera is making clicking noise. If i wait a while it start stuttering and finally get smooth and clear, but it takes a while. So if i don't want to wait I turn on Camera 3d (panoramic) which is working fine always. Then i exit 3d camera. I turn on normal camera again and it's working right away. Now... after about 10 minutes of idle it's not working again. It's like... camera needs to warm up to work. Another wierd thing is when i do a factory reset camera works without waiting, but only at beginning. Could this be a software issue? I tried other camera apps but didn't help. I tried updating with PC Companion but nothing. Do you think flashing software using Emma could help? Also it's a replaced camera, the original one was broken.
profile.country.PH.title
MarlonUk1
unfortunately you wont be able to perform software repair using PCC. have you tried restoring factory settings? and or EMma flash might be a good idea
