Cannot send empty message on lollipop
Ahmedk
Hi guys I need your help, my phone is c3 dual and after I upgraded the system from kitkat to lolipop, the phone is not sending any empty messages what can I do to send an empty message?
Note that I tried to type space, #, 0 without any result
7 REPLIES 7
profile.country.RO.title
_alexdon_
Try settings-apps-all-messages,force stop and clear data. Restart and check again.
alexdon
Ahmedk
Thanks, but I still have this problem even when I copied an empty message and tried to send it, the phone showed a reply "cannot send empty messages"
_alexdon_
How can you copy an empty message? Just copied space? If you want to send an empty message, just press space once.
alexdon
mmh
It is not working also guys
_alexdon_
@Hampus Can you take a look after the weekend?
alexdon
Hampus
Champion
As far as I know, this is how our messaging application is designed to work. It does not work on my Xperia Z3 either. I suggest that you check Google Play for a third party messaging application to see if it's possible to send an empty message from there.
_alexdon_
Don't know why I thought that was possible,just that I remembered sending in the past charity SMS to a specific number but with no message.
LE: Maybe those numbers can receive empty messages?
alexdon
