Change keyboard to AZERTY (instead of QWERTY)
Rnbin
How can i change my keyboard to AZERTY instead of QWERTY ?
Before the update it was easier... but now it looks like i tried everything but nothing seems to work !
If it's not possible anymore, who can recommend a good app to do this ?
Thanks in advance,
Rnbin
Thommo
Genius
Maybe this guide will help you - It was one of the 1st guides i found via a Google search
Rnbin
Thanks, that guide doesn't really helped for Xperia Z3 but I found out how.
For those seeking the same answer: download 'European French' dictionary (settings -> language -> Xperia-keyboard -> manual adjustment (it's at the top)). My phone is not in English so the translation might not be 100% exact. Then download the dictionary, and little keyboards like in this guide of Thommo will appear (they don't appear until you download the french dictionary). Tap the little keyboard et voila.
Thommo
Genius
Thanks for the heads up and a nice touch with the French at the end
