Hi guys,just awhile ago,i went to the pool and took some pictures with my Z1. The pool was 8ft low only. not sure if that is 1 meter deep,but i believe it's not. Now,i am having this problem that my phone doesn't charge anymore i think because it has been 10 minutes charging already and yet still stuck at 0%. When i took some pictures underwater,i made sure every panels of the phone is closed and yes it is,but when i got up,the phone says that the SD card is unmounted,but the cover for the SD card is closed and i'm sure about it. Does anybody know if i can fix this phone alone or i really have to bring this to the service center? Thanks guys!
Sorry to hear. Did you have the phone at the bottom of the pool? Because 8 ft is above the specification for IP-class 58.
I suggest that you disconnect the phone from any kind of power source, hold the ON/OFF + volume up(+) button for 5-10 seconds. When this is done, connect the phone to the charger via the wall socket and let it charge for 1-2 hours. If the battery is completely flat, it can take a longer time before the phone powers on and/or inidicates charging.
Otherwise, you would do best by visiting nearest service center to have the phone examined by a technician. You can contact your local support team for further information about nearest service center and/or how to proceed with this in the best possible way:
http://support.sonymobile.com/global-en/contactUs/
Hi sir,i tried doing the Power Button+Volume Up. i dont know what's happening now but there's a red LED light coming out of the phone but doesn't open,so is it good or still a no? 😕
Edit:it's charging (i think because the red LED light just shows up) but whenever i open it it's gone. then nothing happens. so should i bring it to a service center?
Edit:Just now,the red LED is blinking and my phone is vibrating but the screen doesn't turn on
Did you let the phone charge for a longer time after you held down the ON/OFF + volume up(+) button? You should let the phone charge for a longer time before you try to power it on after this. But if it still wont power on, you would do best by visiting nearest service center to have the phone examined.
