on the fb app it gives u the option to b notified with a rington/vibrate or l.e.d flash or all of the above when u get a msg on ur fb profile.. i have ticked all the boxes and changed the ringtone to suit myself.. but it doesnt seem to work.. has anyone else had this problem??? my partner seems to think its bcoz im using timescape and fb it updating automatically thru that ?? is he ryt?
plz help
do you have an internet connection on all the time for the phone to pick up updates and do you have automatic updates set
it is connected to the web 24/7 and updates every 15 mins?
not sure what the problem is but in timescape mines is up to date with FB/twiiter but the actual FB APP i have is 7 hours old, so maybe its the FB APPS that are down just now
