Filtering Contacts
Mr2_mohsen1376r
Filtering Contacts
Hey everybody,
Does anyone know how to filter contacts in "Messaging "?
Actually when I type a word in filter part, it searches among text of messages and doesn't show the contacts
Nabeel
Master
Hi
I didn't understand it completely , could you help a little bit more by giving more details about what you mean by filtering ?
If I already got it correct then looks like it's not possible with the stock messaging app. You will have to look after a 3rd party app that does that.
How about using Hangouts as the default messaging app ?
If you want to do that, then go to messaging app > options > settings > under general settings, select default SMS app > again select default sms app >  Select hangouts ( if it's already installed on your phone).
