I'm trying to install flash player for w995 however I get an error stating adobe flash player is not available for your operating system or device' ?, it gives me a link to view the systems requirements however not info for Mobile system requirement.
Any help would be great
Bhav
http://developer.sonyericsson.com/wportal/devworld/phones/phone-overview/w995?cc=gb&lc=en As you will see if you follow this link, the W995 is already equiped with Flash Lite 2.0.As far as I know, the full version of Adobe flash is not available for Java OS phones such as the W995, as the error message you're getting suggests.
Having been on the same website on my W995, if you scroll down that page of Adobe flash player system requirements, while it's still loading, you will find that the only compatible mobile OS mentioned is the Android 2.2 (Froyo).
