i forgot my xperia sl pin code.please help?
there is no "fogot pin" option to enter my gmail details!!!
Is it your PIN code for the SIM card that you have forgotten? In that case you should put in your PUK code. Contact your network provider for more information.
Or is it the screen lock PIN code you have forgotten? In that case you can reset your phone by repair/reinstall the phone software using Update Service:
