Google search by voice
I bought Xperia mini in India.. and unfortunately Google dose not support voice command out here.. the flip side is i cannot use google search by voice.
i was wondering if there are any other apps that i can perhaps use..
i was told that such apps are available on 2.1
Uliwooly
You can download the apk here and install it
http://android.modaco.com/content/lg-gt540-optimus-gt540-modaco-com/318904/updated-to-2-1-contacts-h...
or you can directly click here to download the apk, and intsall it.
http://depositfiles.com/en/files/ch7p4q3x3
make sure you go to
settings
               applications
                                       and check "Unknown Sources"
that way you can install the apk.
