Since I did the upgrade proposed by my phone the GPS has totally dissaperad from any menu,
Can't activate it anymore!
Thanks.
Regards,
Philip
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
After the latest update GPS is called "location" instead. You'll find it under settings > location.
