Hi guys. I have a problem with Xneo. When i connect the HDMI cable to the TV and then to the phone ,nothing happens. My phone is android 4.0.4 ICS and TV is a Samsung 32C530 with HDMI + CEC. Please help.
P.S. I did a phone repair and all for nothing.
Have you tried with a different cable or to a different TV to see where the problem is?
I tried an LG TV, same problem. When i insert the phone cable into the phone, the following message appears:
When i pull the phone cord appears: So I think that the cable is good
Well, in that case it might be the phone. Try repairing the phone software via PC Companion and see if it helps. If it doesn't it might be hardware related and then you need to send in the phone to a service center for repair.
