Headphone "detected" on phone charm
spiraboo
Since the last firmware update from last week, my Xperia TX has been thinking that my phone charm that plugs into the headphone jack (these kind of things if you don't know what i mean) is actually a headphone, thus It's on headphone mode 24/7. This never happened before the aforementioned firmware update and I've been using charm for a long time. Does anyone know if there's a way to force disable headphone mode, or do a roll back on the last firmware update? (of course i can just unplug it, but I bought it for a reason and I would prefer to keep it there!)
Thanks!
Johan
Master
Could you please explain more about this phone charm? I'm not sure I follow.
Kaytea1
It's just a charm that goes in the headphone jack to stop dust etc getting in. It doesn't do anything
spiraboo
Yep. what Kaytea said. The head is plastic so you wouldn't expect it to connect with the device in anyway.
perhaps this link will show clearer how they look : http://www.amazon.com/3-5mm-Crystal-Stopper-Iphone4-Cellphone/dp/B008M0R60M/ref=pd_sim_cps_2
