Which headphones are you using?
Try to repair your phone with PC Companion
Tried it, everything is fine with my software.
Can anyone with the same tablet tell me if I am the only one to experiment this ?
Can someone from Sony try and answer me ?
My question (is it only my tablet or do all z3 tablets behave like this) should be easy to answer for someone owning the same device or for any tech from sony... Then I would know if I need to repair my phone or cross fingers for next software update.
Have you contacted Xperia Care?
I though this forum was the place to contact Xperia care...
Howard saoule I contact them ?
