Headset not working
jenny_stenberg_
Headset not working
I have a new tipo dual and my Koss porta pro wired headset with microphone does not work with it.
Problems:
1. The other person does not hear my voice when I use headset (but I can listen to his voice).
2. The other person gets an echo of his own voice when I use headset (but without headset it works fine).
Questions:
1. Is there an adapter that will make Koss porta pro with mic working with the tipo dual? where can I buy it?
2. Is there another wired headset with microphone that will work with the phone? where can I buy it?
3. Is there a software update to the phone that can fix the problems. where can I find it?
profile.country.PH.title
MarlonUk1
the headset might not be compaitble with the phone, have you tried the headset with other phones?
you can look for compatible headsets here: http://www.sonymobile.com/global-en/products/accessories/
Samuel1
Hero
I guess this headset uses the OMTP standard, while the phone uses CTIA standard. There are adaptors out there which makes it possible to use a OMTP headset with CTIA phone and vice versa. It's a hardware difference so software won't help.
Check this thread for more info:
http://talk.sonymobile.com/thread/31455
