HELP ME.. What happen with battery z3..? less than one day.!!!
Seba0284
What I can do,??? The battery is very short... Less than one day... Is my cellphone that failed.??
profile.country.US.title
Qatrium
Go to Settings -> Power Management -> Battery Usage and check what apps are draining your battery most.
Hampus
Champion
The Battery usage menu that Quester mentioned, shows what functions that has used battery since the last charge. So you should check this menu when you have around 5-10% left of the battery.
xavinux
Enthusiast
