hi guys
im using xperia x8
and my phone is stuck on reboot loop
when i restart it brings me to the sony erricson page and does not load from there
it is stuck there forever!
how do i solve this problem? please help someone..
First and easiest, take the battery out for 30 seconds and then try turning on again.
Secondly, if the above doesn't sort it you will need to run a repair via PC Companion or Sony Ericsson Update Service http://www.sonyericsson.com/cws/support/phones/topic/1.433308/xperiax10?cc=gb&lc=en
This will wipe your phone back to factory settings and hopefully resolve the issue. You will lose all data on the phones internal memory but hopefully you have saved your contacts either by sync or to sd card at some point. You can reinstall your apps from the market.
