Help: SE mini W300 (GPRS and e-book)
I just bought my Sony Ericsson Jing Ling mini W300 (it's not the same as w300i. This is what it looks like) and there are two things that I still can't figure out: 1) I can't seem to configure the GPRS settings. Every time I try to connect to the Internet, it always says either "connection failed" or "GPRS not subscribed"; and 2)how can I transfer an ebook (.txt) to my phone?
Thanks in advance for the help!
Dr_Chris
Champion
1) For the GPRS you need the correct internet data account setting which you can get from your mobile provider.
2) To transfer text documents, you can use a USB cable connection to your PC.
