hi everyone! ihave just bought this phone about 10 days ago and i had updated it last night to android 2.1 but i have a problem.i lost some app. and now i cant install opera on my phone any more!it keeps sendind the message that it cant find the settings or someting and tell me to go to www.sonyericsson.com to get the correct settings!i dont know what does it mean?where should i find the settings!?it seems that it cant find the settings for the intenet on my current line but i use Wi Fi to connect to internet not my phone!can someone help me?i live in austria but i havent bought the phone in austria!what should i do?
Check to see if you have an internet accounts setup in your phone and if so, delete them:
Settings > Wireless & Networks > Mobile Networks > Acess Point Names. Delete accounts if you see any.
Now, when you are connected to the Wi-fi network, do you see the wi-fi symbol (extending arches) or not?
Does the internet connection for for anything else?
Let me know and we'll try and work it out.
hey ,thanks for the answer,but right now i can connect to Wi Fi connections and i have the wi-fi symbol do i still need to do that?
no accounts!there is a problem with a programm named slide sam! it seems it cant have the right settings!
