Hidden disabled Apps??
Zero3hero
Hello,
Recently I downloaded ccleaner and in the app manager it shows all apps installed and then it shows disabled apps. I have never disabled any apps but for some reason it is showing 4 apps as being disabled, but when I look in the built in app manager on my phone it shows no disabled apps. What is going on?
22 REPLIES 22
Uliwooly
@Zero3hero
Hard to tell because you are using a third party app, cleaner apps could cause problems, if you are losing app settings/data uninstall it and report back, also posting screenshots and which app you are using it will be easier to help you.
Zero3hero
Hello @uliwooly
I have not used the ccleaner app yet, I was only exploring it's features and that is when I noticed this.
Zero3hero
Why do these apps not show up in the built in app manager? Makes no sense.
Uliwooly
@Zero3hero
I have to wait for a moderator to approve the screenshot or you could upload it to box or dropbox and post the link here
Zero3hero
@uliwooly
Just posted.
Uliwooly
@Zero3hero
That's quite interesting, I'll escalate this, which app are you using to find that info?
profile.country.RO.title
_alexdon_
@Zero3hero What if you expand each app? There is a small arrow pointing downwards, can you post a screenshot with that too?
I am not sure, but some of them might be blocked by the system itself (looking at that startup flag service).
alexdon
Zero3hero
@uliwooly
Ccleaner. And like I said before these apps do not show up in the built in app manager. I have never disabled any apps prior to this.
