hi.........
how i can use my x10 mini as modem to connecte the enternet from my pc ?!
thanks
Friend, I am sorry to say that, with the current firmware Xperia cannot be used as a modem.
I have heard of some third party applications that help you to do this. I haven't personally used any of these applications and not sure whether they will work or not.
thanks
Hi ra85mi,
This is not supported out of the box but it can be done via third party developed apps from Android Market.
Go to Android Market in the phone and type "tethering" in the search box.
Many users recommend the applications "PdaNet" and "Easy Tethering". I have not used them on my own though so I can't recommend them personally.
yes u can use the 'easy tether' for connecting your phone as modem..... i m doing the same using my 3G!
thanks guys, i use pdanet.......... graet result ![]()
