hi,
iam using walkman app and i have multiple playlist which were created on pc and i synced them to sd card using media player in pc.
all this playlist are listed in heading my playlist,
this playlist are playable and are stored on sd card.
whenver i want to add a playig song to playlist , none of this playlist shows up
also i cant edit these playlist.
all the other players like google play music etc doesnt have this problem and works smoothly with editing and add to options.
how can i solve this problem.
the app i use in pc to sync playlist and transfer music to sd card is mediamonkey.
same playlist when stored on internal memory doesnt seem to have this problem.
I think it could be related to the access to SD.Maybe your card is seen as read only.Are you on 4.3?
but other apps are able to do it without issue,
the .m3U playlist files nor the folders have write protection,
The micro sd card is also not write protected.
yes iam on 4.3 and this issue was present in 4.1 and 4.1.2
In this case,you should ask sony about this,if you say the problem was there before:
http://www.sonymobile.com/global-en/support/contact-us/
Or even contact a staff member:
http://talk.sonymobile.com/t5/Welcome/Community-users/m-p/634967
Did you find a solution to this problem?
I've got a Z3 Compact and am having the same issue.
I don't suppose you found a solution to this problem? I'm having the exact same issue with no way of resolving it.
Thanks!
