I'm still new to the droid world, and while I like some of the features, others get me mad (you can say what you want about Apple, it's the best in terms of user friendly features).
Anyway, I've just taken some photos. And I've opened my Sony Bridge. But, I can't see the new photos. I suppose I can only see the photos that are in the memory card ... correct?
My questions are:
- how to force my mobile to always save the photos on the card?
- how do I transfer the photos from the internal memory to my card (I usually wait for the message saying the internal memory is 75% full)
open your camera app>settings>data storage>sd card
to transfer media from internal to sd card. you can use a file explorer ( you can download at play store) locate the images folder (usually named DCIM) then move/cut to desired folder at sd card
Is there any way to store anything I want to my external storage rather than the internal one?
I'm starting to get fed up having to delete apps as my 16GB internal storage is getting full, whereas my 128GB external one is near empty ...
Thanks!
Ok, so it looks like my new question has been moved into an old one, not sure why.
I don't want to move my photos. I want to move my apps into the external memory, not the internal one.
