I get internet : no gateway reply error
      I have been trying to connect to internet through Wifi (broadband BSNL dataone, UTStarcom) from my Vivaz Pro for quite sometime but I am not able to as I get Internet: No gateway reply error everytime. I am able to connect to wifi through my Nokia E63 and my Sony PSP without problem. So the error should be in the vivaz pro itself. I have come across lots of pages where this topic has been discussed but the problem has not been solved. Can you help me with this please?
What do you mean it can't connect? It can't establish a connection? or if you can establish a connection but internet doesn't load?
I get the connection but then when I try to browse it says no gateway reply. The same connection is working fine on my PSP and Nokia phone.
Had the same problem, was an easy fix, just make sure you type your WEP in the correct way with capital letters and all....i didn´t put capital letters but it showed me as logged in to my router anyway, upon trying to connect to internet i got the same message as you got.
After re-entering WEP with capital letters all works fine.
