My old Z310 broke down and I had a lot of info and contacts. A LOT OF WORK AND IRRITATION was to be
How do I save that info in the future so it not will happen with my new ELM??
The companion program is only working with 1 phone at a time. It should be transferrable to other phones within the family
Nilsallan
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/elm?cc=gb&lc=en You can use PC suite from this link to back everything up, including your contacts.
