Internet connection
Internet connection
Hi, I have recently found that my internet connection only appears to work when I am in contact with WI FI, the o2 service seems to have stopped working.  When I have wi fi turned off, as I can't connect when I am not in work anyway I use the usual O2 facilty however in this mode, I cannot download anything.  I seem to be receiving my email notification ok.  Is there something I may need to change in my settings?? Please help becoming very frustrated.
Try resetting your internet connections
Settings>Wireless Controls>Mobile Networks>Auto Internet Settings
Select your service provider and plan if on anything like pay as you go otherwise just the operator and click OK
Also check you do have 3g enabled not just 2g
Settings > Wireless Networks > Mobile Networks >TICK MMS & Data
and
Settings -> Wireless Controls -> Mobile Networks -> Network Mode GSM & WCDMA selected
