Hello,
I have 2 problems
1. My phone does not get any 3G Network when i select WCDMA mode then a cross sign appear on my network, I am facing this problem since last week.
2. How to send a file through NFC i have tried everything but can not use it any help(Post only ion video).
I have tried repair my phone through Sony PC Companion but no luck..............any help?
Regarding the network you should try with another SIM-card to see if the problem might be related to the card.
Regarding file sending, what have you tried so far?
What are your thoughts about this forum? Let us know by doing this short survey.
Thanks for your answer, network problem solve. Now can u help me in "NFC".
If you answer my question I wrote in the previous post I will look in to it!
I don't know how to send file through NFC as i tried sending image,songs,contact but no luck....
I have Xperia Ion & Xperia SP.
can you post a video of sending file through nfc in xperia ion?
Unfortunately I can't post any video but I'll do my best to explain. It's not really difficult
- Activate NFC and Android Beam (Settings > More.. > NFC) in both devices.
- Open up something you want to send (for example a picture in album)
- Touch the other device (normally back-to-back) and you will get a message asking if you want to send the file.
- Click the file and the beam will start
This also works for other apps such as contacts or youtube videos.
i have tried this but no luck..........after i touch both the device(back-to-back) nothing happened.....plz help me
And both phones has NFC & Android Beam activated? Which phone are you using except the Ion?
yes both phone have NFC, i have Xperia SP & Ion both...............
Well, you should try with some other phone to see which of these phone the problem is related to. You can also try to repair the phone software:
